I was back onto wiring again today, installed the connector plugs between the encoder and the D6 EFIS & the connector between the Fuel computor and the GPS.
Also placed the control yoke and flap handle in place to check for any interference between the control yoke and the Mixture & throttle controls.
Not all good news, as when the mixture is at idle cutoff, there maybe some conflict, won't know for sure until the pushrods are all connected to the elevators and ailerons.
Not sure I'll be too worried, Flying the aircraft with the mixture at cutoff doesn't happen often!
