Brief Description: Windscreen and assoiciated trims and mouldings.
Carried on with the screen today, and after working out how the screen is secured at the door post and the orientation of the moulding part 242, clamped this into place and again back drilled from inside out through the already drilled rivet holes, then marked out and drilled the remainderon both sides.
IF only there was a photo like this in the assembly manual
