Having completed the fitting of the auxillary fuel tank to its final position under the rear seats I started to complete some of the items that would be more easily done before joining the cabin structure to the fuselage. Just aft of the rear seats is a great location either side of the bell crank offset for the elevator push rod, for two lockers with lift up hinged covers to hold stuff ( tie down rope etc). so I made up all the parts and etch primed them.
I then started to look at the internal linings that I had purchased with the kit and started the fitting thereof, wherein I found that if I placed all the attaching angle cleats to hold the linings, these may prevent access to some of the back drilling required when fitting the external cabin sides.
So o... internal linings on hold until external cabin skins are done!
