Over the last couple of days I re-assembled the rudder frame (ribs & spar), used tape to hold the rib tips in correct position, made up the temporary table jig frames and marked and drilled the rudder skin.
Rudder framework on the vertical stab.
Looking at the bottom rib and tail wheel steering horn
