Swinnys 4 Place Bush Explorer
Date:  9-8-2011
Number of Hours:  8.00
Brief Description:  Tail cone and rear end corner skins
This area of the tail is quite difficult to get right.
To keep the shingle effect I have installed the tail cone under the two bottom corner skins.
To get the tail cone skin down tight I firstly used bolts to hold it against the tail spring attach bracket (Thanks Don, that made a big difference), and then used the screw type clecos worked around the corners, starting with 3/32 holes and slowly working up to the 5/32 size for the big rivets.
I also installed nut plates on the cone for the side panel covers.
The screw type clecos really need now.
It looks a little better than it realy is!
