Finished the drilling of the right side bottom corners then trimmed the bottom skin to length. Held the skin in place against the bottom stringers and marked all stringers onto the inside of the bottom skin. Started to think about a couple of additional access covers in the bottom skin to allow access to the static port tube connections and also to allow inspection inside the rear fuselage around the tail pull handle area.
