Swinnys 4 Place Bush Explorer
BushCaddy L164
Releasing the fuselage from the jig table
Finished the internal linings in the fuse between frames 02 - 04, then removed the fuselage from the hold down blocks on the table.
Removed the rear flooring panels and turned the fuse onto the side for the first time.
Feels very strong.
Preparing to start on the bottom stringers and skins.
Lots of space in here.
On its' side
Tail end area
BushCaddy L164 Home
3616
A/Filter & Snorkle
Ailerons
Brake systems
Cabin
53
372
Cowls
Doors & Windows
Elevators
Engine Baffles
Engine mount
External lighting &
Fairings
Final Assembly & Ins
Firewall fittings
First Flight & Tests
Flaps
Flaps
Getting sidetracked!
Horizontal Stab.
Instrument panel
Interior Lighting
Internal linings
Kit delivery
Paint Shop
Prop & Spinner
Seat Belts
Seating
Static System
The A P Inspections.
Undercarriage
V-Stab
Vert-Stab
Wind Screen
545
Wiring
