Swinnys 4 Place Bush Explorer
BushCaddy L164
Vertical Stabilser leading edge
Set up string lines offset 20mm to the left of centreline at bulkhead PA01 to establish the suggested amount of offset for the vertical stabiliser to suit my engine.
Fitted, trimed and drilled the leading edge skin.
Checking the Vstab offset
string lines.
BushCaddy L164 Home
3616
A/Filter & Snorkle
Ailerons
Brake systems
Cabin
53
372
Cowls
Doors & Windows
Elevators
Engine Baffles
Engine mount
External lighting &
Fairings
Final Assembly & Ins
Firewall fittings
First Flight & Tests
Flaps
Flaps
Getting sidetracked!
Horizontal Stab.
Instrument panel
Interior Lighting
Internal linings
Kit delivery
Paint Shop
Prop & Spinner
Seat Belts
Seating
Static System
The A P Inspections.
Undercarriage
V-Stab
Vert-Stab
Wind Screen
545
Wiring
