Today I finished the fitting and drilling of the rivet lines on the port side fuselage panels and the fitting of the tail pull bar. The tail pull required no modification and when located had a couple of mm clearance above the rudder cables on both sides. More luck than good planning and management here.
Also completed the riveting and installation of the static port on the Srtarboard side skin.
