In the last two days I finished the fitting and 3/32 drilling of the upper external corners, this ended up being much easyier than I thought it would be and I did not need the screw type clecos.
I used small blocks of wood to fit inside the stringers and spring clamps to hold the skins in place for marking and drilling, starting along the lower side stringer line and then worked up around the corners. The result was a tight fit against the frame on each station.
Very satisfying to stand back and take the pics of progress.
While I was doing this, my heros were taking out Bin Laden, Yahoo !!!
Nearly time for some rivets
Reminds me of the balsa wood models I made 55years ago
