Swinnys 4 Place Bush Explorer
BushCaddy L164
Bellcrank cover in lower rear Cabin area
Made up and installed a HD Plastic guide block at the pushrod penetration of the lower rear cabin bulkhead.
Cut down and fitted the roll tube and elevator pushrod cover.
Made up and using plate nuts, installed the final cover plate to fully enclose the rear cabin bellcrank compartment.
Pushrod guide block at rear cabin bulkhead
Roll tube and pushrod cover
Cover plate
BushCaddy L164 Home
3616
A/Filter & Snorkle
Ailerons
Brake systems
Cabin
53
372
Cowls
Doors & Windows
Elevators
Engine Baffles
Engine mount
External lighting &
Fairings
Final Assembly & Ins
Firewall fittings
First Flight & Tests
Flaps
Flaps
Getting sidetracked!
Horizontal Stab.
Instrument panel
Interior Lighting
Internal linings
Kit delivery
Paint Shop
Prop & Spinner
Seat Belts
Seating
Static System
The A P Inspections.
Undercarriage
V-Stab
Vert-Stab
Wind Screen
545
Wiring
