Swinnys 4 Place Bush Explorer
Date:  6-23-2010
Number of Hours:  3.00
Manual Reference:  nil
Brief Description:  Hydraulic brake tubing.
This morning I completed the hydraulic brake line tubing back as far as the landing gear bracket attach points and then tested the lines for leaks by attaching some tubing and sucking on the lines to see if the suction held. I did this on both sides and confirmed that the system lines had no air leaks, and that the park brake vale worked as intended.
