I missed a measurement on drawing A-C-0078 showing an 88mm distance between the mounting brackets for the spring loading of the pedals, and when I started to mark out the locations for the Brake master cylinder brackets, became concerned that the springs would interfere.
Be careful not to exceed the 88mm.
As it turns out I was only a little bit wider, and by turning the springs around I did not need to re-drill the spring mounting angles.
Also be careful, The assembly manual says that the PF-175 mounting block are to be placed 140mm either side of the centre stiffener angles, this is incorrect.
The 97mm shown on Drwg A-C-0074 is the correct measurement to suit the parts supplied for my L164 kit.
