Brief Description: torque tubes, right wing strut attach
these hours are from the last two days I cut the holes in the cabin for the torque tube from the right wing and fuel lines to enter the cabin also made the torque tube from the right wing through the cabin then i drilled the wing stut fittings for the right wing not easy aligning everything but it worked in the end.
