today i got the gear braces on with the gord mohr fittings the gear is much stronger than stock Also the flap guide is half done the template for the flap guide is not in the instructions so I have to make it from trial and error the last cut cannot be made until the teleflex cable is installed also I used up the wet epoxy chromate to rivet the elevator gussets for the push pull tubes and the avionics tray braces
