the fuel injector lines are rubbing the cowl so I had to make a bump on the cowl I am not good at fiberglass so I found a new use for NACA vents put on facing out instead of in the cowl is done except for sanding and painting then I got some Mothers aluminum polish and started polishing Its going to be a lot of work but it looks great after just a little work
