over the last few saturdays Tudor has helped me make sure the plane is ready for the airworthiness inspection We found 2 nut plates that were not installed in an inspection cover got some adhesive mounts for zip ties to tie up wires in the wing roots updated the skyview system updated the transponder calibrated fuel gauges on the skyview cleaned up the hangar tried to do the skyview backup battery test but it wasnt charged enough to start the test
