these hours are from the last few days Safety wired the turnbuckles, filled and secured the oil cooler lines. filled the header fuel tank, pressurized the fuel lines, fuel pressure cutoff switch needs adjusted, fuel pressure regulator needs lowering 3 psi header tank has a small seep, needs a little welding touch up took the wings off and polished the bottom of the left wing painted the fiberglass tip on the rudder put on the 29" airstreak tires did the fuel flow test its pumping 40 gallons per hour through the electric pump lots of small other things
