I worked on the aileron brackets and the fairlead for the flap cable to go through. I worked on the temporary front floor board. I’m going to use it for holding all the attach points to weld in place. I can also use it for the pattern to cut out the final one.
Update don't always believe the North Land PA-18 drawings the floor boards drawings are wrong
