Brief Description: Right wing leading edge install
With the proper wing washout put into the wing sitting on the table I installed the leading edge. I need to go back and finish putting in the screws that screw into the front spar on the back side. I also got the flap push rod adjusted and set so I don’t have to do that later when I install the flap and rig the wing.
