Brief Description: Riveted front HS spar Left and Right and started s
Finished riveting front HS spar. Had to drill out the 2 holes at the end of HS-706 and dimple the rib. I also had to drill out 4 rivets that I installed in the rear spar by accident. So when the directions say tape the holes so you don’t rivet by accident make sure you tape all the holes. They are supposed to be blind rivets that you install after you install the rear spar. (HS-00005 to HS-603pp). I am also building the right and left at the same time so it's easier when you have tools out and squeezer set to do both sides at one time.
