Glen and I had lunch with the guys at the hangar at CYKF. Visited Ivan at his hangar, he was working on his ELT installation. We borrowed his DRDT2 so we could dimple the skins. Back at Glen's house, Glen repaired a broken screw on the pitot tube bracket while I started deburring the bottom outboard skin(R). Then we started installing the inspection plates. got the holes drilled . We also tested the nav/ strobe lights, they work fine. Called it quits at 1630h.
