Today we finished dimpling the left wing forward section. Drilled a hole that we missed in the corner that goes through the rib(#8). Next we did some repairs to the fuel tanks, removing the capacitory fuel sensors and replacing with the original float type. Had to cut a hole in the end left tank to install the float. Drilled and instaled the nut plate to hold it place. Need a piece of heavier alum to cover up the other hole. Hooked up the fuel gauge to a battery to make sure that it works, yes it does. Did some prelimary planning on the pitot tube bracket location.
