Working on a few things that will improve overall reliability. WE moved the rudder stops up about 1/4 of an inch, this will stop the rudder cables from rubbing on the stops. We changed the baffling around the air intake opening. We removed the mixture cable and replaced with one from Vans which should provide a better hook up to the carb and a smoother operation.
