We removed panels for inspection, our inspection and that of the upcoming MDRA inspection.We did a modification of how the fuel selector is attached to the floor panel over the 604 section, instead of being attached by 4 rivets, it is now attached by 2 screws into nutpales. This makes the floor panel removable without having to remove the fuel selector assembly. Today is Wedneday so we had burgers at Gary's hangar number 18, very good! Then after lunch and a bunch of talking, we were able to borrow a handheld compass so we could align the Dynon 10A remote compass. We had good results, after the alignment was complete, we checked it every 30 degrees with the master compass and was mostly very close with the most out was only 3 degrees. We intend to do another compass check once the engine is broken in and we will be able to run the engine for an extended period of time.
