We removed the tail fairing to check over the SB about the potential cracks in the horizontal front spar emanating from the relief notch. everything looks good. We took some pictures. We also checked for cracks re the other SB from vans, that also looks good. We did find two bolts that had to be replaced because they were not not showing enough thread, so we installed two longer bolts. Talked tp Vito about using his compass swing instrument, should be good enough weather tomorrow to do the compass swing and remote compass alignment.
