Brief Description: Finished HS center bearing assy
Fixed the broken handle on the rivet squeezer-the pins in the handle sheared. Replaced them with 1/4 socket head cap screws. Then I drilled out the smiley rivet and finsihed riveting the center HS bearing assembly. Cleco'd it in place and drilled out the mounting holes with #12 drill.
