Brief Description: Drill and dimple skin and reinforcing angles
Drilled the reinforcing angles and skin. Drilled the spar holes where it connects to the ribs. Disassembled and deburred holes. Dimpled all holes. Eric learns how to debur and dimple parts. Put the dimple set in with the pin on the bottom as someone suggested on line. Too hard to line up the holes this way. Go back to the pin on top like a drill press.
