Brief Description: Cleco'd on left HS skin to HS front spar & riveted
Cleco'd inthe center nose rib and riveted to the left HS skin. Had to drill out two rivets-the rib was not tight to the skin at the very front rivets. Got it tight-Eric held the skin down while I riveted it. Cleco'd in the front HS spar and started riveting. Riveted every second hole and removed all the clecos.
