Brief Description: Deburred holes on Right HS skin
Stripped the blue covering off the outside of the HS skins around the rivet holes. Used the butane fired soldering iron and a yardstick-worked good. Deburred all the rivet holes on both sides of the RH HS skin. Next up is deburr the edges of the skin and dimple it.
