Assembled the spars, spar straps and eleveator hinge brackets. Used the C frame squeezer to set the spar strap rivets. Set the hinge bracket rivets using a CRS steel block and the rivet gun. Drilled out a few rivets that were overdriven. Eric drove a few rivets on the brackets.
