Edge deburred F-1012A and F-1012B clecoed them together. Clamped F-1012E in position and match drilled both the #30 and #12 holes as per directions. Cut F-1011E Rudder Cable Angle and match drilled nutplate holes as per directions, still must countersink nutplate holes. Cut F-1011A from 6' J channel provided. Removed bow from the two F-1011C Horizontal Stabilizer Attachment Bars and deburred the edges. Edge deburred F-1011 and clecoed the F-1011C's in position, match drilled #30 holes as per directions. Clamped and centered both F-1011A and F-1011E in position on F-1011, match drilled #30 holes and clecoed as directed. Drilled the two 1/8" holes to 5/8" as directed
