Brief Description: Stringer and Stringer Web Rivets
Riveted the HS-1014 and HS-1015 Stringers together, then riveted the HS-1016 Web to the Stringers. Failed to follow the order of the instructions in the manual and had trouble riveting the HS-1004 Inspar Ribs to the HS-1016 Stringer Web. Used LP4-3's to complete the assembly as per tech services advice.
