Riveted HS-906 and HS- 912's to HS-1003. Secured Inboard Hinge Bracket Assembly to HS-1003 with hardware indicated. Had to torque AN hardware to 30in-lbs. instead of the 25in-ibs as recommended as this was the lowest setting on my torque wrench. Marked bolt heads with torque seal.
