Brief Description: Installed Hand Hole Doublers, Right Wing
1. Used a shop vac to clean out the inside of the wing from all deburring scraps. Mostlly aroung hand holes in bottom skin. I also tweeked the gap seal to be in line with the top skin. The curve I put in it isn"t perfect. 2. I spent most of the time today deburring the hand hole flanges and spacers. Picture 2 shows one hand hole near the aft spar and truss connection. 3. Photo 3 shows all of the hand hole flanges and spacers Clecoed in place. Care has to be taken to orient each flange the same as all others. You can rotate the flange as necesssary to keep all bolt holes oriented same as all others.
