Brief Description: Gap Seal Adjustment to Wing Contour
I recieved the rivets I needed in order to attach the gap seal. I finished riveting and then I took a 2 lb. ball peen hammer and draped a towel over the ball end. I strapped the wing down tightly to the table and pressed upward on the gap seal as I drug the hammer back and forth under the gap seal. I had to pull upward pretty hard with both hands pressing the ball of the hammer into the underside of the gap seal. This eventually put a curve in the bottom of the gap seal and pulled the duck tail down and got the gap seal top edge to line up with the top of the wing. It came out pretty good but the riveted edge of the gap seal fish-mouthed between rivets. i do not think this will hurt anything. Lastly, i flipped the wing with the help of my wife and checked for twist.
