Brief Description: Began plumbing Fuel tank in Left Wing
1. Fabricated a drill guide to cut 3" fuel hole in top of tank. Installed using pan head screws from kit. Will save these screws and use again later after hole is cut in tank.
2. I need a 1.5" OD dowel to make the drill guide for the fuel sight glass. I have an 1.25" OD dowel so I am adding 0.125" of tape to the outside if dowel. This is just a tool used one time so it should work fine.
