Brief Description: Continued Riveting Bottom Skin on Left Wing
Placed and set ten more rows of rivets on bottom skin. I have five rows left to set. Also I installed the strut exit doubler although it is not mentioned in the instructions. I had to drill out one rivet that the mandrel broke about 1/4" above the top of the rivet head when pulled. Strange to see a failure like this but it was easy to remove and replace. I used a long stick and a piece of tape to retrieve the rivet from inside the wing.
