Brief Description: Straightened Ribs and Adjusted Fit to D-Spar
1. Spent the day trying to eliminate some of the rib twist and bend. Made some progress but still has some unwanted twist. 2. The biggest issue is the root rib is riding about 1/8" high in the fit to the forward spar. I bent the top flange of the rib to bring it down 1/8" but I worry that the predrilled hole in the rib will no longer line up with the skin. Time will tell... 3. Cleoed the ribs back in place and riveted the attach clips to the appropriate ribs.
