1. Deburring aileron spar. The burrs inside the spar are difficult to get out. I ordered a new set of deburring blades made to get burrs inside a tube. Until I get these blades I will work on the other aleron.
2. Drilled aileron hinges and pressed in brass bushings.
3. Installed two inspection ports in aileron skin.
