Brief Description: Riveting Bottom Skin Right Wing
Today I finished deburring the rear spar using a Burraway tool. I had to get a new blade as I broke the only other blade I had. This went well then i used a shop vac to clean all the burrs out from inside the wing. Once everything was clean I started riveting the skin to rib connections. Last I riveted the trailing edge of the skin to the rear spar and called it quits for the day. I still have to rivet the hand holes to the skin,
