Brief Description: Dimpled Leading Edge of bottom Right Wing Skin
First I removed Clecoes from the leading edge plus four more rows. I then deburred both sides of the skin where I drilled holes in the leading edge. Then I used a rivet crimping tool with 120 degree dimple dies and dimpled the leading edge row of holes in the skin. Next I counter sank each hole in the D-Spar. Then I used a Burr Away tool to clean out each hole in the D-Spar. This tool works pretty good but you have to take it apart and clean it about every35 holes. I then used a shop vac to clean all the aluminum shavings from the inside of the wing. I Clecoed the skin back down and pulled the flush rivets in the leading edge of the bottom skin.
