Brief Description: Clecoed and Drilled Bottom Right Skin
Today I Clecoed the bottom skin on the right wing. I started at the aft spar and added Clecos one row ar a time. When I got 3 rows from the leading edge I rolled the leading edge with the tool in picture 1. I set the tool a little too tight and it caused the edge to come out wavey. Next I finished up Clecoing the bottom skin in place and drilled the leading edge and D-Spar, I set Clecoes as i drilled holes and the edge laid down flat. Everything came out good.
