Brief Description: Flipped Wing and Set Bottom Skin in Place
1. I screwed a 2"x4" to the side of each wing support to hold it erect on my table top. 2. I removed the 4"x4" blocks under the wing and let the wing sit flat on table top. I then raised the aft spar upward and got the wing balanced on the nose of the D-Spar. Then I held onto the truss and let the wing roll over gently on it's back. I then put the two wing supports under the wing. Flipping it over was pretty easy for one man. I then checked for wing twist--None. 3. My wife hepled me lift the skin and set it in place. A 3rd pair of hands would have helped. 4. I used a Shaven tool and deburred all edges on the skin and 8 five inch hand holes and spacers. I also used my hole deburring tool on all hand hole "drilled holes" in hope that this small countersink type edge will help me set the pop rivets easily. Put all tinnermen in place on hand holes. Deburred and Clecoed the four tank supports in place.
