Brief Description: Riveted Top Skin and fit up Gap Seal
1. Deburred the left hand gap seal with a shavin tool. It came out good. 2. I fit the top of the gap seal under the trailing edge of the top skin and Clecoed it in place. 3. I finished riveting the last four rows of rivets except not the trailing edge. I removed the supports for the gap seal. I had a scare when I dropped the gap seal from the table to the floor. It bent 90 degrees but right in the support that had to be cut out. All turned out fine. 4. I Clecoed the bottom of the gap seal to the aft spar. This was surprising hard to squeeze to line up the predrilled holes. I had to start on one end and work across the wing.
