Brief Description: Began Riveting Top Skin Left Wing
1. Deburred four tank supports and Clecoed three in place. The fourth would not line up with the predrilled holes in the skin. I tried turning it around, swapping places, nothing worked. I got a 5th out of my parts and it fit right off. I then took the non fitting support and put it back to back with another support and the holes do not match. This support is mis-drilled. I will send RANS a note on this problem. 2. Installed the first three rows of rivets in the top skin of the left wing.
