Home of the Spodplane
Date:  2-27-2014
Number of Hours:  1.00
Brief Description:  F28 - rear face
Applied 2 x BID @ 45 degrees, and one UNI laterally. Had to say it once. Will only again if I do something different to plans for some reason, or want to emphasize a detail.
FHC stiffeners applied to wet layup and 3 x BID applied with 1" overlap onto F28.
Found UNI to be very frizzy at edges, will follow plans reccomendation in future to tape edges then trim. [Time warp 22MAY2014, just discovered pizza cutter will trim off the tape, but not cut the peel ply underneath].
1st layup
1st layup
F28 doubler
F28 doubler
laying up doubler
laying up doubler
