Home of the Spodplane
Date:  1-26-2014
Number of Hours:  1.00
Brief Description:  Finish engine mount inserts
Matched inserts with firewall positions & numbered each. Noted the lower outside corners of inserts got a bit close to edges, so notched off 1/4"
Ordered all required materials for Chapters 04 to 08 from Aircraft Spruce
Cut holes for hard points with Multi tool & coping saw.
Lower insert with notch
Marking up inserts
Marking up inserts
In place
In place
