Removed port brake cover and 40g sanded to profile. Is an absolute bear to get at, but will not be better when the fuselage is inverted, when I'll do the rest of the leg. Came out OK, but there is a slight insufficiency at the trailing edge of the gear leg. Resolve to sand to profile next time with the cover on, and refill this trailing edge a fraction. Happy!
Put the port wheel back on, and jack up the starboard strake, and remove the starboard wheel.
Profile sand the existing fill. Decide the brake line cover extension is just hopeless in profile, and I thought the port side was bad... Sanded off the obvious offending bits and prep sanded the surrounds. Taped up the gear leg and laid some filament tape at the upper target and layed up a 3 x BID revision
