Home of the Spodplane
Date:  7-2-2020
Number of Hours:  2.30
Manual Reference:  21-05
Brief Description:  Port strake inner skin, starboard OD rib, sight ga
Filled a number of bubbles on the inner skin of the port strake top with wet micro, observing actual pinholes in action! Taped over repairs with 1 x 4oz.
Put the inner skin on the starboard OD/smoke oil tank bulkhead, 1 x BID and 1 x 4oz and peel ply. I had forgotten I had hardshelled it so had leftover resin.
Emulating what I had seen in Nick Ugolini's capacitance fuel probe installation instructions, put a 1 x 4oz tape between the starboard strake top foam and the spar/fuselage side. One last bit of EZpoxy sealing before I apply the outer skin with MGS resin.
Fill gaps around ends of sight gauges with EZpoxy flox and tape with 1 x BID.
Patchy, patchy, OD bulkhead
Tapey, tapey
Tapey, tapey
Tapey, tapey
Tapey, tapey
